mastahscott
Feb 15, 2005, 7:09 AM
Post #2 of 4
(4444 views)
Re: [app37le] Help: RCA P46924 46" Big Screen Convergence
I have this tv as well, I hope this will help you . First go to the menu and in I think where it says Screen , there is a thing to set up projection tv . go in there there is some convergence settings in there. It is not even close to that chassis that guy suggested . Now if you need to get serious, you can go to the controls on the front panel turn it on and hold the menu button down and hit the power button, then hit the channel up button This will bring up a thing on the screen with a p0 on the left and a v0 on the right. Now run the v0 setting up to 80, then you will be able to see some convergence you can play with with the volume and channel keys. Take care Scott
