minehunter
Dec 13, 2004, 1:33 AM
Post #2 of 3
(1407 views)
Re: [RPANICO] MITSUBIHI GREEN SCREEN TURNS OFF
The SVM board is a scan velocity modulator. It speeds up the scan lines towards the bottom of the crt so that it is just as sharp a picture as the top where the scan lines begin. By turning off the switch you are turning off the green drive of the CRT. The problem you describe appears to be a short green gun in the crt, It probably needs a new picture tube. I think it's probably time to say good by to the set and replace it. If i had it to there are several test that can be done to confirm it, but they are hard to explain.
