Phillips 55pp9701 convergence screen overlay
Tvrepman
Unregistered User
Docshus@aol.com
Nov 29, 2004, 12:53 AM
Post #1 of 6 (1981 views)
Phillips 55pp9701 convergence screen overlay Can't Post
Hi,
I need information on where to purchase a cross hatch\overlay screen which is taped outside the tv sceen as a convergence referance.The alignment works well.A service tech once used it and I would like to fine-tune the set.I am a tech. and am familiar with the service code to access the service menu.I have checked with Phillips and online with no luck.
Thanks...
Guest
Unregistered User
Nov 30, 2004, 6:52 AM
Post #2 of 6 (1958 views)
Re: [Tvrepman] Phillips 55pp9701 convergence screen overlay [In reply to] Can't Post
I wish I could help with the overlay but I can't. Maybe you could help me? I'm trying to get into the sevice mode on a Magnavox 55p8288. Can you help please? Thanks.
woody
Apr 28, 2006, 11:01 AM
Post #3 of 6 (1140 views)
Re: [Guest] Phillips 55pp9701 convergence screen overlay [In reply to] Can't Post
I have a 55" philips magnavox that won't let me adjust the convergence through the remote. Is there a way to do it manually? Or did you ever get the service code to get to the service menu so I can fine tune it?
FixTips.com
May 2, 2006, 3:05 AM
Post #4 of 6 (1121 views)
Contact Philips here 800-851-8885
Template Part # ST4165
Using the remote, enter the following seven button sequence to activate the convergence service mode:
0-6-2-5-9-7-Menu
(This post was edited by FixTips.com on May 2, 2006, 3:10 AM)
biggmac
May 9, 2006, 10:35 PM
Post #5 of 6 (1089 views)
Re: [FixTips.com] Phillips 55pp9701 convergence screen overlay [In reply to] Can't Post
do you know the code to adjust the size of the picture? I just had some warranty repairs done& i know he put a code in that let him stretch the pisture (not sure if this is the same as convergence) & the picture looks to have re-set after the tech left & i t urned the tv off and on. now i can't see the bottom of the screen & i'd rather not take another day off work if theres a way to just go in and adjust the settings...thanks
Larry E
May 24, 2006, 6:19 PM
Post #6 of 6 (1029 views)
If you don`t have the service manual so you can enter, adjust in sequence, and then properly exit the service menu you are asking for nothing but trouble, Fix-Tips.com should have explained this before giving out the code, I don`t suggest this to any layperson as it will just cost you more when you have to call in a tech, Larry E
