Aug 13, 2015, 5:43 PM
Post #10 of 22
(13589 views)
Re: [Meraux] Sony KDL70R550A No Power
Well, IF you took accurate readings, the board NOT producing 3.3 volts would mean that that board is definitely BAD. Does that mean that replacing this board will fix the set? NO. It just means that to proceed further a known good board will have to be obtained and tried. At that point one of three things will occur: 1) New board will be blown (either arrives defective or fails once installed; 2) Pin #1 voltage will be present, but set will need further troubleshooting; or 3) Set will work normally. You can now (with the set unplugged) put your DVM on a mid range (2K/20K decreasing to a lower range if necessary) ohm function and test each of the previous 5 points looking for shorts (any reading below 100 ohms, especially if you don't have to wait for the meter to stabilize). ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Aug 13, 2015, 5:45 PM)
