tekmenlos
Apr 4, 2006, 5:11 PM
(375 views)
Re: [tiedemannrw] VS-45603 Will not turn on
Hello, try the following: 1. Check IC700 PIN 4 (AC-OFF) for 0 Volts DC. If it's high, check for leaky D980 Part # 264P045040 on the Main PCB. 2. Check for 10 Volts DC at PIN 5 of IC502 of low, check IC503 Part # 270P704010 on the Main PCB. 3. Check R529 which is .82 OHM 1/2 Watt resistor of PIN 4 of the Flyback. If open, check C411 which is a 2200 UFD @ 35V capacitor and IC 451 Part # 270P064020 on the Main PCB. 4. An intermittent shutdown could be caused by low voltage on PIN 5 of IC502, you should have 10 Volts DC. Check IC503 Part # 270P704010 on the Main PCB.
(This post was edited by tekmenlos on Apr 4, 2006, 5:14 PM)
