hackman
Aug 9, 2006, 12:20 AM
Post #2 of 10
(4973 views)
Re: [tjames72] help with dead 57uwx20b rear projection - PLEASE!!
So it’s on, but No HV, or sound? Warning: HV can injure and/or kill, be careful. That said, are the Picture Tubes Glowing (There are little filaments on back of each CRT (I hope this is a CRT TV and not a LDP)? Are the tubes glowing? If they are that’s telling us allot, we know we have some voltage coming from the Flyback. Usually when NO HV or sound, something has 'shorted' out, if vertical gets shorted the TV will refuse Horiz. Deflection , if it didn't there would be a straight line across the screen, and we know if that happens it only takes about 5 mins of vertical line to burn the TUBES, (Same with a Horiz. gets shorted, It may refuse) it only takes about 5 mins before the burn to the TUBES.) You may need some tools, a schematic would be helpful for this unit, you could your voltages (vertical out, Audio B+ at Amps) Be Careful around Horizontal, you should use a variac, and observe all Voltage warnings in that area (HV can hurt/kill) If all is checked and is known good, working, there could be something in standby, or deflection yoke shorted. Observe HV Warnings, and a schematic would help you out! Anything new, post it. J. (hackman) My 2.1 Cents worth.
