Larry E
May 24, 2006, 6:13 PM
(258 views)
Re: [need help] looking for suggestions on keeping the tv circuit board cool
Either you mis-understood this tech or the tech is an idiot, "Hi-Def" is a terminology, the signal coming into your tv`s tuner will NOTcause your convergence circuit to run too hot, most convergence IC`s run fairly warm anyway, if he installed new IC`s and they are running too hot he probably used cheap generics made in china and they are notorious for early failure and running too hot, adding a fan to the inside of your set is not going to make the problem go away, it might delay it for awhile but that`s all, you didn`t give enough info to tell you what to do from here but a fan is not the answer, videotech
