joe_mn
Oct 3, 2005, 9:36 AM
(621 views)
samsung image size
I have a samsung pcj534rf. 4ys old. i had the convergence chips replaced in may. last month a 5watt coated fuse blew. now, i notice that the bottom of the screen is black all the time. maybe 1-2". I also get a thin, maybe 1/4" wide snowy band at the very top of the set. this band only shows up on certain channels. the set is a 4:3 so when i watch WS dvd's, i get black bars on the top and bottom. ok, I can put up with that but now I am starting to get what looks like the RGB convergence grid at the very top of the screen. it almost seems like my image is too small or not centered. how do you adjust the image size? I can access the menu and do the manual convergence setup so i am pretty sure the screen image can also be adjusted. I also noticed when the chassis was out that it says pcj533. similar models? interesting. I use the comcast HD box and there is a "center image" option in the setup menu but that does not seem to change anything.
(This post was edited by joe_mn on Oct 3, 2005, 9:41 AM)
