Mar 29, 2007, 10:56 AM
Post #2 of 3
(2008 views)
Re: [Bobber] Mitsubishi Model CK3526R Hi Voltage, No vidio, lines in raster
Check your fixing, the vertical IC will cause the video to be cut off. It sounds like you turned up the G2. If the jungle is not getting feedback from the vertical IC even though you have scan the jungle does not know that, and has blanked out the video.
