denonjapan
Nov 10, 2009, 7:40 AM
Post #4 of 6
(3577 views)
Re: [Alston518] Sanyo DWM 400 help
Alston, if you are truly in school for electronics?. Help isn't what you seek when you want to prosper. This is no insult!> Pay attention to the class, and don't let the professor go on without you understood the subject. The more you ask, is likely you will succeed. This is just the beginning and consider it your simple test...I don't normally handouts easy resolutions to nobody but since someone already poured a poison, ( a person rather to be seen ) other than to help you benificially towards your career. Here's the problem:> dvd mechanism ( lens,motor, spindle and all consisting in the assembly). when frozen appears, it locks all commands. DVD player this cheap is totally can wear and tear out at anytime, no guarrantees. There's nothing wrong with the electronics where you presumably spray to contain heat related.LOL! people in this forum just gets on my nerve. Not to you though!!! denonjapan made in japan
