Nov 7, 2008, 8:08 AM
Post #27 of 28
(1950 views)
Re: [denonjapan] Sony DVP-NC600 spinning issues
You poor stupid fool, there is no belt on the spin motor. All you you do is dig your hole deeper. Now you have changed your font to red, perhaps like some cooked prawn the end is near. A DVD player is a cheap unit, not designed to be fixed. The thing has all of its parts, bearings , capacitors ETC designed to last warranty . If you wish to fix the unit, you are going beyond the manufacturers specifications. I give you a fix which kept the thing going till out of warranty. I have never seen a disc spin by a belt, I doubt it could happen but am open to suggestions. Your grease ( which I see you dropped) is an ignorance. You han no idea but delved into your small pocket of knowledge and found GREASE. So carry on in your attemt to divert from the subject, to where you feel at comfort, its all a divertion from what causes a spin motor to spin. Im sure you will find another alley to squirm up to avoid addressng the issue. I ask now where did I ever talk about an alloy of Iron and copper, You find it and Ill answer it. Please study Phosphur bronze bearings and forget other mixes, You found the father of this bearing and stopped there, it has been refined since that.
