jdiazsandi
Unregistered User
jdiazfar@yahoo.com
Apr 16, 2004, 8:08 PM
Post #2 of 5
(3653 views)
Re: [Guest] dead Sony DVP-NS315
I have a similar problem with the same model of DVD player Sony DVP-NS315, but the component damaged is apparently a Relay, Voltage Regulator or don't know. It's position is IC101 and it is located by the side of the small transformer, it has a screw with a heat disipation plate welded to the board. I propose I check on my board your diode D212 and you check on yours the IC101. I don't have the board here at hand now, but tomorrow I will check it and find out which part number for cross reference is your diode. I'll greatly appreciate if you can help me too. Thanks
