denonjapan
Sep 3, 2005, 7:27 PM
Post #4 of 4
(3472 views)
Re: [kookie] dvd player won't read disc
don't use any commercially disc cleaner ( like disc with brush in it) those only contaminate your laser. Im suggesting you to open the unit, get a cotton bud, wet solution and gently brush it thru the laser lens. don't worry if the liquid gets inside. after doing so! get a blow dryer! in hot mode / direct it thru the lens in 5 seconds, repeat in same sequence and that's it! .....Your dvd player doesn't respond immediately, if problem still persist. Run it playing for a while.....if it doesn't work still! You will then know whether or not you need new laser!. denonjp
(This post was edited by denonjapan on Sep 3, 2005, 7:32 PM)
