dvd won't power up
michaela
Jan 9, 2011, 3:12 AM
Post #1 of 8 (4547 views)
dvd won't power up Can't Post
Hello, I have a Magnavox MDV456/17 DVD player, and after a recent power surge the player will not turn on. I unplugged it and opened it up, and found some pink gooey stuff leaking inside, which I cleaned up.
Does anyone know if there is a quick and easy repair to get the player working again (such as replacing a fuse)? I hope so because I don't really want to buy a new player. Thanks!
Jan 9, 2011, 3:57 AM
Post #2 of 8 (4544 views)
Re: [michaela] dvd won't power up [In reply to] Can't Post
NOT like they cost $1,000,000 to replace.Crazy
michaela
Jan 9, 2011, 5:53 AM
Post #3 of 8 (4541 views)
Re: [jts1957] dvd won't power up [In reply to] Can't Post
Thanks for the non-help. Anyone else?
Jan 9, 2011, 6:16 AM
Post #4 of 8 (4536 views)
Start by measuring for Raw B-Plus voltage. Proceed to secondary voltages if has Raw.
Also post picture of "pink" stuff.
michaela
Jan 9, 2011, 4:04 PM
Post #5 of 8 (4531 views)
Believe it or not, when I went to take a picture of the "pink stuff," I discovered that my digital camera is also malfunctioning.
Anyway, I do not know how to measure for voltage on a DVD player or anything else for that matter. Is it easy to explain how to do it?
Jan 9, 2011, 6:57 PM
Post #6 of 8 (4529 views)
DVM - set to measure DCV - One probe on each pin of the largest electrolytic capacitor on the power supply board - Red on "plus/positive" terminal and Black on "minus/negative" terminal.
Don't slip and be Careful, that cap can give you a decent shock or give off a fairly large snap/spark if accidentally shorted out. Expect at least 150 Volts.
michaela
Jan 9, 2011, 11:09 PM
Post #7 of 8 (4525 views)
This sounds dangerous and kind of complicated. On second thought, perhaps your earlier advice was better after all!
ian33
Jan 17, 2011, 2:54 PM
Post #8 of 8 (4515 views)
if so change the power supply
