denonjapan
Dec 6, 2008, 2:03 PM
Post #2 of 5
(8595 views)
Re: [Mamacat] New TV - not receiving digital signal
mamacat!,..... 1st, it's strange that your so called television stations ran a digital test for 5 minutes and you are able to set the tv 5 minutes less than that...... well, never mind I said that, perhaps the reason all you did was plug and play which you should re-scan the channel "AGAIN" after connecting it to the converter box. Also, I doubt that your Polaroid tv has digital tuner built in cause if it has, You don't need a converter box.......People often wrong from having thoughts, make sure verify this info thru the manual. denonjapan made in japan
