bvbull200
Jul 7, 2005, 12:48 AM
Post #4 of 4
(1290 views)
Re: [Guest] DVI or RGB Component Cables?
The DVI connection eliminates the need for your HD STB to make a digital->analog conversion and your TV then making an analog->digital conversion. You should, but will not always, get a slightly better picture with the DVI connection. It's best to just hook it up both ways and see for yourself. Personally, with that model (having only one DVI input) I would use good quality component video cables for your High-Def source, then get a good quality upconversion DVD player and hook it up through the DVI connection, that should get you the best of both worlds! And don't underestimate the value of good quality cables!!
