TANK1
Jul 23, 2006, 9:40 PM
(1483 views)
Re: [ratchet] Difference between Toshiba 30 HF 66 and 30 HF 85 please!
ATSC & QAM Tuners let you connect just an over the air antenna or basic cable ( no cable box- only receives analog channels 1-99 ). Invar Shadow Mask; A shadow mask is a thin sheet of perforated metal behind the screen that restricts electron flow, each hole in the sheet corresponding to a single pixel. An Invar mask uses an alloy that's especially resistant to the high temperatures generated by the electron beam, allowing in a brighter, clearer picture. Black Level Expander - Increases the black threshold level, so blacks are pure black, not dark gray. This significantly improves overall picture contrast. Benefit: Improved contrast makes picture appear sharper and more three-dimensional. The 30HF85 looks like the better set for the money because of the extras including HDMI
