Mitsubishi HD6000 Receiver Question
rptvbuyer
Feb 15, 2008, 2:30 AM
Post #1 of 7 (104 views)
Mitsubishi HD6000 Receiver Question Can't Post
Obscure question. Receiver came from a Mitsubishi Plasma, having an issue with the HDMI out not able to synch to 2 different plasma with HDMI in. Is it known that there maybe a firmware or Setup trick if there may need to be a change to make it work as a standalone unit thru HDMI? Component outputs from this work fine...
rptvbuyer.
denonjapan
Feb 15, 2008, 2:54 AM
Post #2 of 7 (100 views)
Re: [rptvbuyer] Mitsubishi HD6000 Receiver Question [In reply to] Can't Post
Perhaps your displays are not multi-synchronized. There are firmware for setup for those displays. what model are those?
denonjapan
made in japan
rptvbuyer
Feb 15, 2008, 5:49 PM
Post #3 of 7 (96 views)
Re: [denonjapan] Mitsubishi HD6000 Receiver Question [In reply to] Can't Post
Not sure it unit worked in the first place. Could be intended for or came with a plasma Mitsubishi plasma set. Component outputs work fine.
2 Sets tried are Pioneer PDP-4340HD with a PDP-R06U receiver and a Hitachi 50 which is much like a Pioneer PDP-5330HD.
rptvbuyer.
denonjapan
Feb 16, 2008, 12:14 AM
Post #4 of 7 (93 views)
The media receiver you have was for the diamond plasma series from MITSUBISHI, which is muli-sync display. Professional and Consumer standard. Model: PD-5050. The Pioneer PDP-4340HD is a consumer alone displays which don't permit your application by HDCP compliance through HDMI of 2 unrelated media receivers. I don't see why either.................
denonjapan
made in japan
rptvbuyer
Feb 16, 2008, 1:22 AM
Post #5 of 7 (89 views)
Attempting to get a service manual to see if it shed some light. It was mentioned that it was bought as a standalone receiver, not sure from searching net if it ever was sold that way. I hooked it up to another set a 73" Mits Medallion to the DVI input and also connected the MonLink RS232 cable between them as an experiment..
I see the screen on both sets for a second in pink then
pinkand of fine snow then no picture and it cycles over and over. It may be bad, awaiting a service manual, maybe it has a setup to configure or ?
It is a nice recevier.. typical mits menus..
rptvbuyer
Feb 17, 2008, 2:41 PM
Post #6 of 7 (80 views)
Service amnual did mention much. found option factory menu, not much there related to HDMI or maybe a standalone option.
It does use Silicon Image Sil 9190 HDMI TX IC for its output. Going to get a user manual for it and see if thast adds any info. I get a picture with orange cast for 3 seconds then ornage casted fine snow then blank secreen then repeats, like it its trying to find?
Need to find out what Mitsubishi G-Link is, MonoLink and something about a "Promise Module"?
rptvbuyer
rptvbuyer
Mar 5, 2008, 12:26 AM
Post #7 of 7 (43 views)
Appears that it works with the newer Mitsubishi panels
only thru the HDMI port.
Long journey.
