DaymonH
Oct 23, 2012, 6:52 PM
Post #3 of 4
(2110 views)
Yep! Make sure the aspect ratio is set to 16:9 for wide screen. Then you can use the "format" button on your remote to adjust to the correct screen size. Anything that's broadcast in 4:3 will show up as a square in the middle of your screen. If you want to watch it in full screen you can "stretch" it using the "format" button on your remote again, but when you go back to a program that's broadcast in HD, or 16:9 it's going to look funny again, until your reset it with the "format" button. Most people just live with the square picture on SD 4:3 broadcasts instead of constantly switching back and forth. Hope this helps!
