Feb 2, 2012, 10:44 PM
(1664 views)
Re: [PyroPlasm] Disable old CRT
Take a SPARE piece of coax cable. Cut off one of the threaded fittings and install a AC plug in its place. Thread the coax onto the antenna connector, turn the TV on, insert the plug end of coax into AC outlet and enjoy the fireworks. EDIT: The above would be connected to disable the TV. It would be removed (and original antenna reconnected) once fire department leaves ... I mean the fireworks die down. ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Feb 3, 2012, 12:28 PM)
