replacing back light
landon1956
May 18, 2015, 3:20 PM
Post #1 of 13 (4898 views)
replacing back light Can't Post
can someone tell me how to replace a black light on an Acer computer monitor?
May 18, 2015, 5:38 PM
Post #2 of 13 (4895 views)
Re: [landon1956] replacing back light [In reply to] Can't Post
You take the bad one(s) out & putz the good one(s) in. Tongue
Hoping to attract insects? Or going to use for forensics
landon1956
May 22, 2015, 4:32 PM
Post #3 of 13 (4876 views)
Re: [jts1957] replacing back light [In reply to] Can't Post
Fifty thousand comedians in the area and I have to get one of the most fucked up meatballs on the planet.
Maybe you should get a life and try to understand what a person is trying to ask. Or maybe the moderator should take you off the site for your silly uncalled for statements. Or maybe you missed your calling to go on stage with Moe, Curly and Larry. By the way is that one of your names?
You know it is not funny when someone wants information and maybe not as "sharp" at ssking as you when being ask questions. To make it sound correct for a simpleton like you (not directing this to you as you are the worst asshole for questions). I would like someone with a little tech knowledge:
I would like to know how to get to the backlights on a Acer x223w to make a check to see it they are causing the trouble. But knowing you, you like to impress your cohorts with a funny line. NOT VERY FUNNY.
Hopefully your mother will forgive you.
May 22, 2015, 5:39 PM
Post #4 of 13 (4872 views)
landon1956;....
NO matter WHAT you think of jts1957 , there is a ZERO tolerance for foul language at THIS forum !!!
IF you do NOT go back & edit out or change the foul language , I WILL recommend you for PERMANENT banishment..
I have a 100% success rate on banishment...
Think I'm kidding , TRY ME !!!
You seem to need some anger management therapy..
I suggest you do so...
IF you'd take the time & spend some effort to check on jts1957's prior posts , you'd see that he IS A VERY SMART tech & has helped MANY others with their problems...
You need to take other people's comments at times with a grain of salt !!!
CHILL OUT !!
Furthermore , you give NO MODEL NUMBER IN your original post , & expect the techs here to be able to give expert advice on lacking info...Shocked..
NOT smart on your part...Unsure...
Have you read this yet ???
http://www.tv-forums.com/...;;page=unread#unread
It says there;=>..
Include things like:
  • the make and model of your equipment
  • describe the symptoms
  • describe any other information that may help someone help you.
  • above all - be polite and courteous at all times.
So who's "Moe, Curly and Larry" now ???
Later..Ron.M...Cool...
(This post was edited by Ron.M on May 22, 2015, 6:01 PM)
May 22, 2015, 6:54 PM
Post #5 of 13 (4859 views)
Some people cannot replace batteries in a remote control without: putting the batteries in backwards, losing the battery compartment cover or breaking the plastic latch that holds the cover in place.
Without identifying information in a poster's initial offering, I usually treat their posts as if from 'La-La-Land.'
Based on the vast amount of details in the body of your initial post I believe my answer was a fair one.
http://www.ccflwarehouse.com/lasotu.html
http://www.ccflwarehouse.com/ccdulaas22lc.html
Of course taking the LCD panel apart to get to either of the above options is a project unto itself and unless you are careful (or lucky) you can easily damage the TFT glass, the connections where tabs are bonded to the TFT glass and/or driver PC board(s) or even just mess up the order & orientation of the LCD panels' pieces.
(This post was edited by jts1957 on May 22, 2015, 7:04 PM)
landon1956
May 23, 2015, 4:23 AM
Post #6 of 13 (4843 views)
Re: [Ron.M] replacing back light [In reply to] Can't Post
I WILL NOT edit my post and furthermore you can banish me until the cows come home. I couldn't care less because of some stupid silly answers I am getting.
I would think that if jts1957 was as smart as you say he is he would be smart enough to recognize that there was a greenie (newbee) on the other end and would take that in consideration when responding to a question. He could ask in a way that I would be very happy to give him any information that he needed to fulfill my question. But no, he comes back with some silly ass reply. No help to anyone.
In conclusion, I have come to the realization that you, Ron, and jts1957 are bar room buddies and you will defend him until the end. No questions asked.
Oh, by the way, you said to me, "You seem to need some anger management therapy..
I suggest you do so... "
Well let be tell you that I just got cleared by the institution and have a letter that says my anger was ok. Do you have a letter?
Au revoir, adiós, 再見, and До свидания. Also, say hi to your Mother.
May 23, 2015, 4:37 PM
Post #7 of 13 (4829 views)
landon1956....
One would think that a 59 year old man would have more smarts...
Yep !!!!!...
There was ooodles of info in your initial post...
jts1957's crystal ball must have been out for service when you posted & MY ESP malfunctioned due to an earthquake !!!...
""greenies (newbees)" usually are MUCH MORE polite & accommodating when asking for help...
NOT belligerent & arrogant as some people are...
& YOU COULD'VE/SHOULD"VE read the info here;=>..
In particular;=>..
>>> above all - be polite and courteous at all times. <<<
But , I digress...
Too bad they didn't recall you as they do with automobiles...Unsure..
Therapy either failed or went amok ...Pirate..
I don't have the problem you have , therefore NO need for anybody's approval..
While it's true that I consider jts1957 a friend , he'll tell you that I have criticized & corrected him in the past & he has done the same to/for me...
You apparently misread/MISUNDERSTOOD the entire POINT in my last post...
I WILL defend this forum to the end & NOT any particular individual...
HMMmmm , they changed the name of "this" forum from
LCD TV Forum
to
HD TV Forum ????
Oh , well ...
Au revoir, adiós, to you also...
May 23, 2015, 4:51 PM
Post #8 of 13 (4821 views)
LCD Forum = four levels down.
NOT his first rodeo. Many do involve 'model' number in one way or another.
http://www.tv-forums.com/...=Show+user%27s+posts
Forum indicated landon1956 was 'writing reply.' Either he was using Invisible ink or his Mommy told him to NOT post. Crazy
(This post was edited by jts1957 on May 23, 2015, 5:15 PM)
May 23, 2015, 5:23 PM
Post #9 of 13 (4810 views)
jts1957;...
I went & checked some of his past posts , thanks to your link...
Seems that he DID get some VERY GOOD help from you...
He has NO reason to complain about your comments..
He's just an ingrate OR he's OFF his meds...
Also , in this post;=>..
http://www.tv-forums.com/...i?post=159176#159176
he says;=>..
Well, I do understand now what you are talking about the panel. I looked at mine and I think it is just too much for me as a amateur to tackle a job of getting to the insides of the panel.
So , IF he's having a problem (& HE IS) changing a panel , HOW the hell does anyone expect him to change backlights ???..Crazy..
Have a GREAT day , weekend & Memorial Day....Smile..
Later...Ron.M...Cool...
landon1956
May 23, 2015, 5:24 PM
Post #10 of 13 (4806 views)
Apparently you don't have the balls to banish or you have to answer to someone else to be able to do that.
May I take it on myself to self banish myself. Just can't stand being around such crude assholes as you two. Especially you Ron.
You said "Too bad they didn't recall you as they do with automobiles...Unsure..
I don't have the problem you have , therefore NO need for anybody's approval."
My answer: I dont pretend to be a Psychiatrist like you, Where did you get the degree? Another thing, Have you read and understood the book on "How to win friends and influence people?" If not I am sure that will be a perfect start for a Scum Bag (notice the capital letters).
I will say in closing that if you two was banished from this site it would be much better. Seems like some logical people on here that are willing to help.
And again Au revoir, adiós and may you have a pleasant life in the here after. Maybe you should carry some Ice and fans.
Good riddance to you two "fine gentlemen".
Again say high to your Mother for me.
May 23, 2015, 5:46 PM
Post #11 of 13 (4794 views)
landon1956;....
For the record , I HAVE gotten OVER 200 people banished...
This IS PROVEABLE !!!
Banishment is NOT instant...
Today , in case you hadn't noticed , IS SATURDAY...
Admin is also on another continent...
Different time zone , etc...
I WILL request your banishment..
Have NO doubt about it..
PLEASE DO !!!
NO NEED to pretend to be a Psychiatrist when it's obvious that someone like you DOES need help...
I STRONGLY urge you to get back into an anger management rehab center...
ALL of us here ARE UNPAID VOLUNTEERS that , I for one , refuse to take abuse from people like you...
Certainly looks like you DID NOT !!!...
landon1956 , again Au revoir, adiós and may you have an unpleasant life in the here after.
I WILL have PLENTY of Ice (For my cocktails) and fans (Supporters) at my place on the other side of the pearly gate while you shovel coal into Satan's furnaces...
Good riddance to you...
(This post was edited by Ron.M on May 23, 2015, 5:53 PM)
landon1956
May 23, 2015, 8:47 PM
Post #12 of 13 (4785 views)
WOW, Admin is also on another continent..and I thought you were the one.
You sounds like a spoiled brat to me. Maybe I was mistaken about you needing a Psychiatrist.....I think you should have had a nice boat paddle across your ass when you were young and maybe that would have changed your disposition. Hell, who knows you may have made a preacher of the gospel.
We are having a barrel of fun, aren't we?
May 23, 2015, 11:00 PM
Post #13 of 13 (4781 views)
I thought he said he was going to take care of himself himself:
Search for (options) - Page loaded in: 0.17 s on (CGI/1.1)
