Nov 21, 2014, 6:59 AM
(2586 views)
Re: [landon1956] sanyo dp424840
There can be ONLY ONE Model Number ... You will need to remove plugs to remove 'cabinet back'. (BACK CABINET REMOVAL: Remove 17 screws to take the back cabinet off. (C: 3x14, 13pcs; D: 4x8, 4 pcs)) You've only removed the 'Back Lid.' (BACK LID REMOVAL: Remove 2 screws (A: 3x6) to take the Back Lid off.) So I'm presuming you found the "Repair Flow Chart: Trouble Condition: Green Power LED and LCD backlights are on, but no video or OSD." It's the ONLY flowchart that has tcon as 'last one' ? Shop Jimmy shows two possible tcon boards for that model number: http://www.shopjimmy.com/...models=Sanyo+DP42840 However, one would think that if it were the tcon at fault that you would still have sound on the various inputs? ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Nov 21, 2014, 7:03 AM)
