SD-643HD5 Pioneer HDTV Projection TV
abadan
Oct 17, 2005, 12:03 PM
Post #1 of 3 (786 views)
SD-643HD5 Pioneer HDTV Projection TV Can't Post
My Tv Switched to Standby mode on its own and would not turn on anymore( It would try to turn on but relays contacts would not stay closed and it switch back to standby mode)
I checked and found a 4Amp/125V fuse is blown. I have not replace it yet. I was wondering if there is something else I need to check before I proceed.
I checked the forum and found other people with almost the same TV with similar issue.
Please advise.
denonjapan
Oct 17, 2005, 11:10 PM
Post #2 of 3 (783 views)
Re: [abadan] SD-643HD5 Pioneer HDTV Projection TV [In reply to] Can't Post
When your tv is equipped with FUSE protection: I would say the ENTRY protection of all internal parts before affecting the entire unit. Just replace the blow fuse and ur good to go!........don't forget to get extra fuses if it may happen again.
Take note! blow fuse can cause your TV when it is ON. Avoid the use of other ELECTRIC MONSTER such as: IRON, VACUUM CLEANER. at thesame time.....just a tip!
denonjapan
made in japan
ljm576
Jul 26, 2007, 7:36 PM
Post #3 of 3 (187 views)
I am having the exact same problem! Where the heck is the fuse!?!?
