Samsung TXS3082WHX (RCA sound output with HDMI and Component)
theevamonkey
Feb 25, 2010, 1:54 AM
Post #1 of 5 (1793 views)
Samsung TXS3082WHX (RCA sound output with HDMI and Component) Can't Post
I have a Samsung TX-S3082WHX/AA TV.
The problem I have is that I have an older amplifier with a pair of RCA inputs. I get sound from the composite inputs out via the RCA output with no problem. But for devices connected via HDMI and Component, I can't get sound out through the RCA outputs on the TV. I've been through all of the menus a dozen times. Is it just not possible?
Any help would be awesome. Thanks.
Feb 25, 2010, 8:47 AM
Post #2 of 5 (1787 views)
Re: [theevamonkey] Samsung TXS3082WHX (RCA sound output with HDMI and Component) [In reply to] Can't Post
I assume you have sound on the tv when HDMI input is being used from DVD or Satellite box but nothing out of the Red/White audio out sockets. It may be there is only digital sound out from the optical connection when using HDMI though its a bit unlikely. Nothing in the book about this? Worth phoning Samsung helpline as it may be normal for this model
theevamonkey
Feb 25, 2010, 2:03 PM
Post #3 of 5 (1785 views)
Re: [techchris] Samsung TXS3082WHX (RCA sound output with HDMI and Component) [In reply to] Can't Post
I do get sound to the onboard speakers, and the problem I have is not just on the HDMI inputs, it's also for the Component inputs, which is a little mind boggling, because the Component inputs have RCA sound inputs, so it's still sending analog audio into the television.
Feb 26, 2010, 2:32 AM
Post #4 of 5 (1781 views)
So your expecting something beyond 20 - 20,000 Hz of frequency?Crazy
denonjapan
Feb 27, 2010, 8:20 PM
Post #5 of 5 (1771 views)
Try this: from the sound output of your tv: there maybe a selection of settings: PCB and DOLBY DIGITAL. Set it to dolby digital. The amp should recognize it no matter how old.
denonjapan
made in japan
