Icefog
Feb 14, 2015, 4:26 AM
Post #1 of 3
(3184 views)
Samsung UN60EH6003FXZA No Video
Plug in power and you get a solid standby light. I do not have the remote. Use chassis joystick to turn it on: you get start up sound, back light, and the standby light flashes 6 times then STBY light stays off. No video. I've tried signal thru all source input except coax. I think the previous owner last source used was coax. Trying to see if at least I get audio from the coax input. I can shut it down with the joystick by pressing it once, then down, the pressing again. I imagine if I could see the video I'm dong a proper shut down. I do get the shut down audio then back lights turn off and then a solid STBY light. If I do get audio from the coax input then I'm going to highly suspect the TCON board. There is 13v at the fuse. Any other thoughts/ideas? TIA
