TANK1
Oct 17, 2005, 5:55 PM
Post #2 of 6
(1302 views)
Hd is used with a dvi,hdmi,or component video cables. Hd can come from over the air.If you live near a city AND your local channels are broadcasting in HD.You need a antenna,just a regular tv antenna will work.You also need the HD set to have a digital tuner to accept the HD signal from the antenna and broadcast on your set. If your HD set dosen't have a digital tuner you can get a sat reciever which has a digital tuner built in or a just a plain digital tuner.Or you can get cable,they will send the HD signal thur their cable system to a digital cable box which you connect with either dvi,hdmi,or component video cables. If you get sat service you will need a HD sat reciever. With cable or sat you can also watch regular channels with the dvi,hdmi,or component video cables.
