zolo
Aug 31, 2006, 8:01 AM
Post #1 of 6
(719 views)
i have been betrayed by the hd tv
hello to all every1 out here....... ppl i have a serious problem...... i purchased a sony wega trinitron 34" drc hd tv back in 2003 (model no "kv-hs34m91" with super fine pitch and drc.... similar to its newer one the "kd34xbr970")...... my model that is the kv-hs34m91 supports the following resolutions: 1080i@50/60hz 720p@50/60hz 576p/i@50hz 480p/i@60hz these resolutions r truly hd....but the problem comes here..... this tv does not have an HDMI or a DVI input on its rear.....but instead has G,B,R,HD,VD inputs on its rear that is a component cable together with hd and vd cable........when i contacted sony they said that g,b,r,hd,vd is same as hdmi and dvi only they all have different cables for high definition connection... my question is how will i be able to connect a playstation3 which has an HDMI cable to my tv is there an adaptor to convert hdmi to g,b,r,hd,vd or will i get a g,b,r,hd,vd cable for the ps3??? or will i need to sell this one and get a new hd tv with hdmi and dvi........ pls reply thanx in advance.......
(This post was edited by zolo on Aug 31, 2006, 9:18 AM)
