JohnRocks
Mar 10, 2012, 8:38 AM
(2052 views)
Re: [Eugen6] How to connect Pc to TV?
I think you should try using the basic video out instead, and then connect it to TV video in or it’s Depending on the TV your card may not initially work properly with S-Video. When the card looks for the TV it will test for a 75ohm load on one of the wires. If this load isn't detected or isn't in range, it will then send all the picture data on another line, thus causing the Black and White picture you're getting. The control panel for your display can help you force the correct output. ----------------------------------------------------------------- Rackmount LCD Monitor USB KVM
