LCD Problem Please Help
midjam
Oct 14, 2007, 9:48 AM
Post #1 of 4 (340 views)
LCD Problem Please Help Can't Post
Hi guys i`m hoping you can help me with this.
I have a Vistron LCD tv that has some strange colour problems they seem to jump around the screen.
So I did a google search to see if anyone else has had the same problem and found this on you tube :
http://uk.youtube.com/watch?v=UBEN4ijMWBM
Its exactly the same problem i`m having and someone wrote this as a comment:
"That is weird. I don't know why an lcd would do that unless the signal board is messed up. But I didn't think that it could just swap back and forth in that case. There may be a component that is loose or has a bad connection at the solder joint. See if, while it is doing that, giving the tv casing a good tap or smack effects it."
So gave the screen a little tap and it returned to normal, but every now and then it would come back so just a little tap would return it to normal again untill today when a little tap stopped working.
I took off the back and had a nose around to see if any of the plugs where loose but theres nothing odvious.
Could anyone here tell me where to and what to look for?
I could add a photo if that would help.
Thanks in advance
Oct 14, 2007, 10:46 AM
Post #2 of 4 (335 views)
Re: [midjam] LCD Problem Please Help [In reply to] Can't Post
looks like a solarized picture.check the connections on the scaler/video processor board. if you cant see anything prod around with an insulated plastic stick to try to reproduce the fault and tie it down to a certain area of the tv.its a loose connection somewhere if you can whack the tv and clear the fault
midjam
Oct 14, 2007, 10:52 AM
Post #3 of 4 (334 views)
Re: [techchris] LCD Problem Please Help [In reply to] Can't Post
Thanks techchris for your fast reply.
Could you give me some tips on finding the scaler/video processor board.?
Oct 14, 2007, 2:11 PM
Post #4 of 4 (329 views)
usually the board which has a multipin lead going to the screen. it may be under another board or back to back with another as these flat panel tv's dont have easy access to panels like crt sets did.
