denonjapan
Dec 3, 2008, 2:11 AM
(1138 views)
Re: [supaboy] LCD TV and LCD Monitor - difference?
Apple cinema displays are designed solely for architects and businesses. You can't compare them at any monitors pricewise cause Apple monitors are usable for mc'intosh pc only and is above windows, windows xp or vista consumer counterparts. They're twice expensive than any current full hd monitors around not because the panel is better but the intended use in designing aspects are accurate and due to this nature in design, highest resolutions is required. An that's what makes apple expensive. Again, a higher resolution monitor has got nothing to with better contrast ratio, or pixel refresh rates compared to our current 1920 x 1080 monitors. A current 50 inch monitors with full hd are maximum pixel resolutions applied for video. Consumerwise, it's best for browsing Internet as well, However not quite good enough for architects as far as designing is concerned. denonjapan made in japan
