Nov 29, 2011, 1:15 AM
Post #6 of 13
(2068 views)
Re: [sparkie491] LCD on a porch question
sparkie491;.... For me it is the ONLY answer !!!! For you , not so good........ You can also try a GOOD used rear projection HD TV... They have 3 small CRTs in them... The ONLY thing that concerns me about that is that that type TV has acrylic lenses that hold ethelyne glycol CRT coolant (NO wise answers here , please) that may be a problem... I'm not worried about the coolant , but the lenses... O* is a lot colder than what the sets were designed for... But it may be worth a shot , IF the price is right... IF you do go that route , make SURE the porch is WELL warmed up as it WILL take longer for the set to lose any condensation that may be built up inside... GOOD LUCK on your quest........ Later...Ron.M....... Veteran & Retired TV technician
