MJS60
Aug 2, 2016, 10:16 PM
Post #1 of 12
(4311 views)
LG47LN5200 UB LCD TV - Backlight LED's
I guess shorted or open backlight LEDS on LG models are a very big problem? I would have thought that they would have been more reliable than the older florescent bulbs. I guess not! After finding out that 4 LEDS had failed I bought one LED strip on eBay and it did fix one string on the TV that I assume was shorted since the strip didn't work at all. I was hoping to use the good LED's on the used strip to fix 3 other strips on which one LED is dead(open). These other 3 strips all worked except for a single LED out. So I assume that they were all open while the culprit was shorted? The strip I bought fixed the one LED that was shorted and pulling down the power supply so I had 4 good LED's left to work with on that strip. I must say that the heat gun that was recommended on an Youtube video is no match for a good Metcal soldering station with a tweezers attached and is much more difficult than it looks to desolder the LED off the strip. My question is, after desoldering one LED off another strip and without adding a new LED, why can't I get the strip to work now? Pad is not damaged nor is there a solder bridge. I thought the LEDS were all in parallel on this strip? If so they should have lit with only that one LED gone. Any suggestions? Youtube video I used is at: <a href="https://www.youtube.com/watch?v=Bf5T2wwtydY" target="_blank">https://www.youtube.com/watch?v=Bf5T2wwtydY</a> <br>
(This post was edited by MJS60 on Aug 3, 2016, 6:07 PM)
