JBL
Jan 28, 2009, 1:20 AM
(1086 views)
Magnavox autoprogram finds weird channels
Help: A friend has a 32MF338B lcd hdtv. It is being used in a bar where there is a remodulator box that has an outdoor antenna, a DISH feed and a DIRECT feed. Dish is rebroadcast on 35 and direct on 40. We installed the Magnavox and when the autoprogramming was done the channels were: Channel 8 CBS on antenna is on ch 8 on tv (fine) Channel 13 NBC on antenna is on ch 13 on tv (Fine) Channel 19 ABC on antenna is on ch 70 on tv Channel 25 FOX on antenna is on ch 123 on tv Channel 35 DISH feed is on ch 86 on tv Channel 40 DIRECT feed is on ch 91 on tv I think that the tv is set to cable instead of antenna which is causing the shift. For the life of me I can't find where you switch it in the menu. Magnavox tech said to do the autoprogramming again. No success. Any suggestions? Thanks Joe
