Bear549
Feb 2, 2009, 8:24 PM
(2214 views)
Mitsubishi LT-52149 HDMI Input Issues
I am curious if anyone has access to this TV to see if they can duplicate the problems I am having to see if it is an inherent problem with all Mits LT series TVs. I Have a Dish HD receiver connected to HDMI 1 and a DVD player connected to the component input 2. (I do not think it really matters what devices are connected as long as one is HDMI.) If I go into the menu on the TV and name these inputs as SAT and DVD, then when I switch back and forth on the inputs or turn the TV off, the HDMI input will not hold the video or audio settings and always reverts back to factory defaults. The component settings stay as they are set. If I do not rename the inputs and leave them as HDMI 1 and Input 2, the settings will not revert back to factory and the TV works as it should. The TV prompts you to name the inputs from selecting from the drop down menu when you connect a device to it. I do not understand why Mits would have their menu set like this if you are not allowed to rename the inputs without losing your settings? Any suggestions or information I can get on this would be greatly appreciated.
