Tristan
Aug 3, 2016, 10:55 PM
Post #1 of 3
(2455 views)
Polaroid 42", Is this a safe repair?
I'll try to make this as brief as I can. I've spent the last week trying to repair a Polaroid 42" LCD (model TLX04244B), which was turning off quickly after powering on. Looking online, I found others who said the power board is at fault. That seemed to line up perfectly with my issue, so I ordered the replacement part from ShopJimmy.com. It did not fix the issue, however. I then realized the replacement part was a slightly different revision of my original part, so I ordered a new board identical to the original and received it today. Still no luck. I was fed up and in a final act of desperation I flipped a switch on the power board, which I've included an image of here: http://imgur.com/a/IzDqS I first switched on both the 40" and 46" switches, and the TV turned on and stayed on! I could not believe it. Not wanting to harm it, I powered down and tried it with only the 46" switch activated. That worked just as well. Like I said, I had basically given up on getting it to work, and I thought I would give it one last shot. I'm not familiar with TV repair, but I've worked with electronics enough to know to generally leave things the way I find them. Now to my real questions: Is this a safe fix? Will this be a lasting fix? I'm cautious about repairing things like this since I know relatively little about them. If having that switch activated could cause overheating or any danger, I won't take my chances with it. If it's intended use was factory testing or the like, I don't want to take any risks using it. If someone more knowledgeable than I has any experience with this, I'd appreciate any feedback. Until then, the TV is unplugged and not in use.
(This post was edited by Tristan on Aug 3, 2016, 10:56 PM)
