Sharp Aquous LC46D64U blinking green power light
rfitts46
Feb 17, 2018, 2:25 AM
Post #26 of 55 (5055 views)
Re: [rfitts46] Sharp Aquous LC46D64U blinking green power light [In reply to] Can't Post
Forget the comment not going to flashing green.
Feb 17, 2018, 2:45 AM
Post #27 of 55 (5051 views)
Post #16 results?
rfitts46
Feb 17, 2018, 3:16 AM
Post #28 of 55 (5048 views)
Re: [jts1957] Sharp Aquous LC46D64U blinking green power light [In reply to] Can't Post
Measured Voltages on main board P2603 connector:
Pin 1 3.3V
Pin2 3.3V
Pin3 0V
Pin4 0V
Checked connector on Inverter board 1 LB 2603 (9 pin)
Measured 2 pins at 3.3 V and 0V on the other 2 pins
(This post was edited by rfitts46 on Feb 17, 2018, 3:39 AM)
rfitts46
Feb 17, 2018, 4:02 AM
Post #29 of 55 (5043 views)
Finally opened up the link at the bottom of the post i copied and pasted into my post #16.
On the 4 pin connector main board P2603 pin 3 is the error signal and it measures 0V.
Is this where i jumper the 3V from pin 1 or 2 and feed it back to pin 3?
Feb 17, 2018, 4:09 AM
Post #30 of 55 (5042 views)
No link was pasted end of #16.
Using a isolation resistor (1K ohm) - Yes Two 1.5 volt batteries in series would also suffice.
rfitts46
Feb 17, 2018, 4:20 AM
Post #31 of 55 (5040 views)
The content in Post #16 of this thread I copied from another thread. The link was in the other thread, it showed the pinout of the 4 pin connector on the main board. But to be honest it was taken from the service manual, schematic of main board.
What do you mean by use an isolation resistor 1K?
Dont use a wire jumper, use a 1K resistor? Insert one lead into pin2 and the other into pin 3....pin 3 would see 3V?
(This post was edited by rfitts46 on Feb 17, 2018, 4:29 AM)
Feb 17, 2018, 6:24 AM
Post #32 of 55 (5035 views)
That's where I found P2603/LB.
Best case:
https://imgur.com/a/0GetO
rfitts46
Feb 17, 2018, 1:30 PM
Post #33 of 55 (5030 views)
Used a VDC power supply. Did not cut the error wire between inverter board and main board. Connected 3VDC to the exposed connector lead on the inverter board connector. Measured 3VDC at pin 3 P2603 (error) main board. No back lights.
rfitts46
Feb 17, 2018, 1:49 PM
Post #34 of 55 (5028 views)
With the 3VDC present on mainboard P2603 pin 3 pressing vol up and channel down with the room lights off..... can see the tv's small input message block. pop up, upper right hand corner of screen. Flashes on few about 3 seconds and goes away. Can read HDMI and Stereo.
rfitts46
Feb 17, 2018, 2:43 PM
Post #35 of 55 (5025 views)
How about a schematic for the inverter board/s?
Feb 17, 2018, 9:15 PM
Post #36 of 55 (5009 views)
Pix & sound?
Would need to know which Inverter boards are in TV to try.
http://www.shopjimmy.com/...dels=Sharp+LC-46D64U
(This post was edited by jts1957 on Feb 17, 2018, 9:21 PM)
rfitts46
Feb 17, 2018, 9:59 PM
Post #37 of 55 (5002 views)
RUNTKA323WJZZ
RUNTKA325WJZZ
Will hook up a DVD player and see what happens.
Have not heard any sound yet.
rfitts46
Feb 17, 2018, 10:29 PM
Post #38 of 55 (5001 views)
Hooked up DVD player using the red, green, yellow RCA connection...no picture...and pressed input until sound was present and there was some noise (sounded like static and then it stops in a repeating pattern .
rfitts46
Feb 18, 2018, 11:33 PM
Post #39 of 55 (4977 views)
Decided to try a different DVD and audio works along with seeing image using flashlight. So appears definately an inverter or bulb issue.
Feb 19, 2018, 5:38 AM
Post #40 of 55 (4970 views)
With as old as the set is, unless you have a scope to lay probe near inverter transformers to see if have momentary Oscillations, I'd visually confirm bulbs inside panel.
rfitts46
Feb 19, 2018, 12:28 PM
Post #41 of 55 (4967 views)
Do have a scope.
Can you explain the set up procedure(scope settings) for laying a scope probe near inverter transformers looking for oscillation. These inverter boards have a thin rectangular transforner (about 1" x 1-1/2"). There are 4 terminals on primary side, berween 1 and three measure 1.8 ohm on the secondary there are two terminals that meadure open? There is a small bobbin type coil after these as well.
What do the oscillations tell you?
Any images and notes on taking screen apart to inspect tubes?
(This post was edited by rfitts46 on Feb 19, 2018, 12:42 PM)
Feb 19, 2018, 2:03 PM
Post #42 of 55 (4963 views)
Approx. 10 ohms or less on Primary - Hundreds to thousands of ohms on Secondary.
https://www.badcaps.net/...owthread.php?t=21243 Post #2 in particular.
That HV drive is present.
As far as panel disassembly, Usually fairly self-explanatory. Connections and TFT panel are rather fragile. Be careful.
(This post was edited by jts1957 on Feb 19, 2018, 2:17 PM)
rfitts46
Feb 20, 2018, 4:28 PM
Post #43 of 55 (4956 views)
Still looking for schematic for RUNTKA323/325 inverter boards. Using RUNTKA396 as a reference for now.
Feb 20, 2018, 10:19 PM
Post #44 of 55 (4955 views)
What controller IC is being used on Master inverter?
rfitts46
Feb 20, 2018, 10:38 PM
Post #45 of 55 (4953 views)
BD9883
Feb 20, 2018, 11:25 PM
Post #46 of 55 (4950 views)
https://badcaps.net/...amp;highlight=BD9883
Happy reading.
rfitts46
Feb 24, 2018, 7:31 PM
Post #47 of 55 (4925 views)
Is it safe to assume that the C7558 (.47uF/10V) that sits on IC7501 lead 9 error amplifier input 1 on my inverter board is the same C7558 capacitor that the gentleman on the badcaps thread you had me read is the same? His inverter was for a different sharp lcd.
Feb 24, 2018, 9:57 PM
Post #48 of 55 (4923 views)
No.
The point I hoped you pick up on was the result. Turned out Lamp was causing shutdown.
rfitts46
Feb 25, 2018, 2:01 AM
Post #49 of 55 (4918 views)
Yes I picked up on that. But before dissassembling to inspect bulbs it would be nice see back lights come on...if for no more reason to narrow down which bulbs? The inverter has the OZ9928SN CCFL backlight inverter controller.
Feb 25, 2018, 2:56 AM
Post #50 of 55 (4917 views)
Then you'll need to bypass your controller's shutdown and put a single uniform pattern Red, green, blue or gray raster onto screen.
Opening panel will allow observation of all bulbs even if screen only flashes On a single brief time. Plus some bulbs fit into sockets that may have somehow come loose.
Differs from posts #44 & 45?
'Similar' reference pdf covers a 26" & a 32" (which is quite blurry).
Search for (options) - Page loaded in: 0.19 s on (CGI/1.1)
