May 27, 2014, 1:15 AM
Post #4 of 6
(5191 views)
Re: [SilentR] Samsung LN46B630 Power Supply Voltages
Isn't the PS & Inverter combined? hence 'IP' 5-7-1. LN46B630N1F Parts List Location No. Code No. Description & Specification Q’ty S.A/S.N.A Remark T0003 BN96-09495A ASSY COVER P-FRONT;46,LB650,UO,PC(CLR)+P 1 S.N.A T0175 BN96-09463C ASSY SPEAKER P;8ohm,4pin,10W,R:250/ L:60 1 S.A M0215 BN07-00705B LCD-PANEL;LTF460HF06 1 S.A M0215 BN81-02364A A/S-T CON LTF460HF04;LTF460HF04 1 S.N.A M0254 BN61-04800B HOLDER-SIDE AV;UO,PC+ABS,V0,BK25,H/GLOSS 1 S.N.A M0115 BN61-04788A BRACKET-STAND LINK;46, B610,SECC,T2.0 1 S.N.A M0174 BN44-00265B IP BOARD;I46F1_9HS,I46F1_9HS,0.1mA,10.5m 1 S.A M0146 BN61-04818A BRACKET-PANEL TOP;B650-32,SECC,T1.2 2 S.N.A M0014 BN94-02597E ASSY PCB MAIN-SSH;LN46B630N1FXZA 1 S.N.A T0101 BN61-04817A BRACKET-WALL;46, B610,SECC,T1.6 4 S.N.A M0013 BN96-09518A ASSY COVER P-REAR;46,LB650,UO,PC+ABS,V0, 1 S.A M0027 BN96-09501A ASSY STAND P-BASE;46,LB650,TEMPERED GLAS 1 S.A If so... 1) bad Main; 2) Bad bulb or connection inside panel; 3) defective replacement whatever you are calling "I've already replaced the inverter board (used from Ebay)" ------------------------- Location: Far, Far Away
