looking for power supply schematic
streamview
Feb 26, 2018, 2:45 PM
Post #1 of 10 (3356 views)
looking for power supply schematic Can't Post
hi every one.
I am looking for a schematic for Samsung TV power supply l46s1v_dsm.
any chance some one have it?
the TV is Samsung un 46f5500
thanks
Feb 26, 2018, 7:03 PM
Post #2 of 10 (3351 views)
Re: [streamview] looking for power supply schematic [In reply to] Can't Post
I can't find one. BN44-00611A or D / PSLF141S05A are other numbers you can Google.
If Dead/No backlights, on some models unplugging CNM803 should allow LEDs to light until you unplug set from power.
streamview
Feb 26, 2018, 7:29 PM
Post #3 of 10 (3348 views)
Re: [jts1957] looking for power supply schematic [In reply to] Can't Post
I tried also to search for BN44-00611D , but didnt find any. <br>when I plug the tv to the power , it will turn on normal 20% of the time. <br>i checked the standby voltage , ad its ok. and from the main board i have 3.2 come for 2 second to the power supply ps_on ad then it become 0 again , 3.2 v then 0 v and keep doing this untill the power supply kick in , then ps_on stay at 3.2 volt. i feel that there is something wrong with the power supply. <br>if I unplug the cable , sometimes the backlight come on and sometimes no. <br>
(This post was edited by streamview on Feb 26, 2018, 9:30 PM)
Feb 26, 2018, 10:52 PM
Post #4 of 10 (3342 views)
Can I presume A5V is present as long as set is plugged into Mains? What happens if you apply an external 3ish volts to PS_ON? IF all the time the 3.2V volts is present the set works normally then Main board is more likely.
streamview
Feb 27, 2018, 2:46 AM
Post #5 of 10 (3336 views)
yes i have the A5v always as long as I apply power.
thanks for pointing me to test with external 3.2 volt.
tomorrow I will try it , and see what will happen.
streamview
Feb 27, 2018, 9:51 PM
Post #6 of 10 (3330 views)
so I turned on TV without the CNM 803 cable , and there is no back light.
I applied external 3.3 volt to PS_on , and still the same , no back light.
I guess this means that the power supply is bad.
Feb 28, 2018, 1:36 AM
Post #7 of 10 (3328 views)
What happens with CNM803 plugged in and external 3.2V applied to PS_ON?
You said:
(This post was edited by jts1957 on Feb 28, 2018, 1:39 AM)
streamview
Feb 28, 2018, 1:40 AM
Post #8 of 10 (3323 views)
I tried it too , plugged cable from main board too CNM803 and I applied 3.2 V external , and tv didnt turn on and no back light.
Feb 28, 2018, 1:51 AM
Post #9 of 10 (3321 views)
If your model is one that Samsung decreed would fire up backlights when Main board was unplugged, then you have a bad Power Supply. Although how set could work normally 20% of the time earlier beats me.
(This post was edited by jts1957 on Feb 28, 2018, 1:52 AM)
streamview
Feb 28, 2018, 11:53 AM
Post #10 of 10 (3315 views)
sometimes from first ON ( apply power ) it turns on and stay on , the moment I shut off, then it can not turn on anymore . I have to turn on off many times untill it works again.
I hope someone here will find the schematic . its easier to troubleshoot. otherwise i have to spend 2 hours drawing it.
