TDown
Sep 25, 2016, 11:29 PM
(1804 views)
Samsung 55" Inverted color Need Help
Hey everyone. I'm having issues with my Samsung 55" LN-T5265 LCD tv. The problem is that the color is distorted or inverted in appearance. I did some research and concluded that replacing the T Con board would fix this issue. I bought a new T Con board but it did not change the picture of the tv at all. Another place online said that the problem could be a loose cable connection to the tcon board so soldering the edges of the clamp on the tcon board could possibly fix it. This did not work either. I've messed with the settings and reset it to its factory settings but nothing seems to be doing the trick. In the configuration settings all is good except the HDMI configuration is a failure. Do any of you know what's wrong or what I can do to fix this myself? Thanks, TDown
(This post was edited by TDown on Sep 26, 2016, 2:37 AM)
