robsellars
Nov 1, 2011, 4:05 PM
Post #1 of 4
(2892 views)
Soldering Capacitors on LCD Monitor
Hi Hopefully someone here might know how to help with this and save me buying a new monitor! For the last couple of weeks Ive been trying to fix my LCD monitor and I think Im at the point where I need to take it to someone to have a look. I have a Hyundai Monitor W240D, which Ive had for 3 years. About 4 weeks ago the screen started to flicker, then it just appeared to go black. It’s a totally dead picture. When you switch it on, you see the screen lighting up for a second, then it just switches off again. After a bit of reading about I suspected it was to do with faulty capacitors and so I bought some more of the same ones, and replaced. This seemed to work fine for a few days, and then it went back to the same problem again. I thought I might have re soldered on some wrong so I pulled the monitor apart again, and resoldered everything. Again, it all worked for a few days again and then back to the same thing. Ive done this a number of times now and have the same thing each time. Do you know what could be causing this? Is it something any of you have seen before? Thanks Rob
