budro
Aug 15, 2012, 3:18 AM
(1938 views)
Sony KDL-46S4100 no backlight video or audio
I have a Sony KDL-46S4100 that the backlight will not come on. Power light turns on steady no flashing. Even with a source plugged in you cannot get the input to switch to it to turn on the screen. If I disconnect connector CN303 I get the Blue, Red, Green test pattern. So I know the inverter board, panel and backlight work. I tried a different main or A board and had the same results they both have the exact numbers just different serial's at the bottom. Tested the fuse on the T-con board and getting power through it. Here are the voltages I am getting at the power supply connectors: Powered ON: CN301 1-15.71v 2-15.71v 3-0v 4-0v 5-7.18v 6-0.01v 7-3.44v 8-3.44v 9-3.43v 10-0.01v 11-0.01v 12-0.01v 13-11.60v 14-0.00v CN301 Powered Off:all are 0.00v except pins 2,7,8,9 these are 0.05v CN302 Powered on Powered off 1-0.00v 1-0.00v 2-0.00v 2-0.00v 3-3.28v 3-3.29v 4-3.28v 4-3.29v 5-0.00v 5-0.00v 6-0.00v 6-0.00v 7-0.02v 7-3.28v CN303 powered on Powered off 1-0.00v 1-3.25v 2-0.17v 2-0.06v 3-N/C 3-N/C 4-1.69v 4-0.22v 5-0.00v 5-0.00v I know pins 1 on CN303, 1 on CN302, & 7 on NC302 are all low voltage or 0volts which control the backlight circuits. My question is do these voltages come from the power supply or are they returned to the power supply board from the main or A board? Any help would be greatly appreciated. I have ordered a power supply but wanted some others opinions as well.
