ciucca
Dec 24, 2009, 12:55 AM
Post #7 of 15
(4078 views)
Re: [Rogelio] Toshiba Inverter HS32WV12 repair needed
Hi, I'm glad to here you fixed your TV. I have the exact same set with the same problem, burnt out CCFL. I tried a known working inverter and the problem still exists. I would like to open the panel to check for broken burnt CCFLs. I'm a computer tech, and I've never tried replacing a ccfl before, I have a couple of question if you do not mind answering. 1) where did you purchase the ccfls? What is the website and CCFL order number? 2) How do you open up the Samsung LCD panel to get at the CCFL? from the front or back? 3) How easy was it to get the bulbs out? TIA.
