ivtec
Oct 17, 2016, 1:22 PM
Post #4 of 5
(1912 views)
Re: [jts1957] Vizio M421VT LED TV won't store custom settings?
Hijts1957;,i have bad news,you maybe right,about the EEPROM,well i spoke too soon about that i had it fixed but the next day turned tv on and all custom adjustments were not there but the Factory default, i did exact per,fanny tv stores antenna settings and channels ,input,se labels and most of everything else i did set up per instructions using home mode instead of Store mode, and went through the install process,then turned off tv and turned it on all was good. but next day everything went to default ,what a bummer, I guess i have to use Back light forcefully at 85 that's the minimum best default pic settings,which is Game, Football, which is a nice pic anyway, it also has back light at 50 with cinema setting but it's too blur due too low contrast and color, forget about the back light leds extended life.
(This post was edited by ivtec on Oct 17, 2016, 1:28 PM)
