josearias
Feb 25, 2009, 11:41 AM
Post #3 of 3
(1447 views)
Re: [techchris] polaroid FLM-3232 not speaker sound
if it usually cuts out the tv sound when you plug in the headphones then probably the headphone jack socket has broken away from the print inside..have you checked in the menu to see if speakers are switched on or off? Yes, I checked the socket, and the menu is OK. When I test the speaker power output on the IC TDA8932 is when I'm not geting sound. I have the data sheet for this IC, but I'm not sure about how to test it using pin 13.
