Robroy
Jun 16, 2005, 3:50 PM
Post #4 of 4
(2107 views)
Re: [manamok] Burn in and a SONY KDE-50XS955
The orbiter moves around ever so slightly so you won't notice it with the naked eye. The white screen saver is a white wash and should never have to be used. If you have an image burned in you can turn on the white wash and use it to fade the rest of the screen to match the burned in portion, but it will significantly reduce the over all life of your set because it is fading or burning all your pixels prematurely. Again, I wouldn't worry about it unless you have a computer hooked up to it. Just be sure to use the full screen mode whenever you can and don't leave your TV on for long lengths of time with the CNN news ticker left on and also those stupid little logos in the corner like UPN, TNT or ABC.
