denonjapan
Feb 2, 2006, 2:00 AM
Post #4 of 5
(1502 views)
to cut long story short, the movie (or video) you're comparing early on,between your plasma and your quote "cheap tv". As far as why Picture looks better on the ANALOG TV than your PLASMA ? > is bec. the movie simply wasn't recorded digitally. it doesn't matter whether you have digital cable feed to your plasma, when the materials you're watching are enhanced from analog recording. Therefore your cheap tv (analog) seems to look better cause the movie is analog recording itself. It is best fit to analog tv rather than watching in a PLASMA. You said "Does it matter that I have digital cable going into the Plasma and regular old cable going into my old TV? I can't tell if you are saying this is normal or not? ANSWER> Im assuming that thru your hi-def receiver, a COMPONENT output connected to your plasma and RCA outputed to your analog TV. Is this way you made your comparisons? if so! it doesn't matter!. It's the resolution of the movie you made the comparison from. if you ask me if it's normal? No it's REALITY! denonjapan made in japan
