Gatchers
Jan 14, 2005, 7:29 PM
Post #71 of 218
(12002 views)
Re: [harry7623] GOODMANS GTV42P3 42 " PLASMA TV
Hi, To be honest, I wouldn't really recommend the switchless multi-SCART adaptors, as you often get signal muting if you have several input scarts plugged into one output - for example, when I tried one and input frolm a Dreamcast, PlayStation 2, Xbox, Gamecube and set top box, I found that if the Dreamcast was connected, even when off, the right sound channel didn't play at the same volume as the left when watching TV from ther set tolp box. Similarly, having the PS2 reduced the green level, etc. What I would recommend is the ones with switches and some AV inputs - you can work wonders with these. They usually have an A, B, C input switch and some C->A, B->A selectors for AV etc. you can select what inputs you want to use, you can chain them together for loads of inputs, and you don't lose quality. It provides a useful hookup to my surround sound system too, and passed through RGB from each input. My setup means I have a primary switcher, which selects from 'Set top box', 'DVD player' or 'consoles' - 'consoles' is the input from a second switcher, from which I now switch between Gamecube, Xbox and PlayStation 2. This means only my GTV42's RGB input is being used, and I get fully RGB quality out of everything. I got my switchers from Game and Tandy - first one, then the other. Though they both look different, they work identically and have the same inputs/outputs. One is a B-Tech, the other I can't see from where it's situated...
