JohnnyBoy
Feb 5, 2005, 8:30 AM
Post #149 of 218
(3081 views)
Re: [Gatchers] GOODMANS GTV42P3 42 " PLASMA TV
Well, here goes, initial impressions on my new P4. Bearing in mind my previous one was a P, it wasn't even marked P3, and oh, when i say 'was' I still have it. The Argos guy said he wasn't down to collect one, so at the moment we have 2 42" plasmas, we're sooooo posh! In the main, I can echo a lot of Gareths comments, the connectivity is better, navigation is better, on my other one that menu system was really cheap, this is slick and sharp looking, and moving from source to source is a breeze. PIP is good. The style of the new stand in that it hides the cables is good, although it does mean it's now impossible to reach the On/Off switch, other than going round the back, very strange design, why not put a subtle little button next to the others on the front? The Auto detection of the screen format works perfectly, it was so annoying before. OK, the negatives so far. 1.Mine has a whistling buzzy noise from the back of the unit unfortunately. 2. With the settings I currently have the picture isn't as crisp as I would have liked, even for a 'cheap' plasma. 3. Whilst the famous 'painting by numbers' is much better on the whole, I still get it at times, especially on moving faces. 4. Grass on football matches in particular is again much better, but still often looks like it's been painted. So, apart from the noise, which I guess an engineer could come and sort out, I don't want to rule the TV out just yet, as it's early doors, and things might settle down, but it would have to be better than it is at present for me to keep it. Gareth, as we seem to have the same TV now, and you report no probs on yours, even with what used to be one of the worst on mine, i.e. Corrie, could you post your settings, and I will set mine up the same, to see what impact it has Cheers John
