LG50 Plasma wont turn on when cold
medic22
Apr 16, 2014, 2:41 PM
Post #1 of 11 (6412 views)
LG50 Plasma wont turn on when cold Can't Post
I have a LG50 plasma that when it is cold ie 70 deg or less it will not turn on unless you sit there and keep clicking the remote for 100 cycles or more. The power light will turn to green and then right back to red. I have put a small portable heater in front of it and that has reduced the amount of cycles it takes to get it to come on. Once it does come on the TV works perfectly. When I do turn it off it will come right back on for 30-45 min and after that its back to cycling the power again. I need some advise please. It is in the bed room and my wife is having a fit with it being 100 deg in there all the time. Thanks!!
Apr 17, 2014, 3:10 AM
Post #2 of 11 (6401 views)
Re: [medic22] LG50 Plasma wont turn on when cold [In reply to] Can't Post
Once it is on - LEAVE it on 'til it dies.
medic22
Apr 17, 2014, 11:14 AM
Post #3 of 11 (6398 views)
Re: [jts1957] LG50 Plasma wont turn on when cold [In reply to] Can't Post
After reading some of the responses on other posts I kinda expected the lame bull crap from you instead of some real advise. You sir are a waste of good air!!!
xgc12
Apr 20, 2014, 2:39 PM
Post #4 of 11 (6388 views)
It sounds like the power supply. Do you feel comfortable taking some readings with a multi-meter? Or maybe taking the back off the LG and looking for bulging capacitors?
Owner Atlantic Audio & Video
www.atlanticav.net
www.facebook.com/atlanticav
medic22
Apr 21, 2014, 11:03 AM
Post #5 of 11 (6379 views)
Re: [xgc12] LG50 Plasma wont turn on when cold [In reply to] Can't Post
Yes. I have no problem with doing both.
xgc12
Apr 21, 2014, 9:12 PM
Post #6 of 11 (6371 views)
Ok. Open the back of the television and take a look at the power supply first. Do you see any leaking or bulging capacitors? Also could you give us the full model number of the lg?
www.atlanticav.net
medic22
Apr 22, 2014, 11:09 AM
Post #7 of 11 (6365 views)
It is a 50PC5D-UC. I will pull the cover tonight and see what they look like.
medic22
Apr 22, 2014, 8:32 PM
Post #8 of 11 (6358 views)
Ok. As I look at the power supply from the back on the left side opposite where the 110v ac plugs in I see a row of capacitors. Their are 5 of them the same size a row of 2 and a row of 3 right next to each other. As I look at the ends of them with the X all 5 of them are bulged out on the end and kind of discolored. Below the row of 3 there is another capacitor of the same size that is bulged and discolored.There is also another capacitor of the same size on the very left of the board where there are 3 plugs that is also bulged and discolored. All the other capacitors that I look at on the rest of the board and the other boards the ends are nice and flat and bright silver.
xgc12
Apr 22, 2014, 9:33 PM
Post #9 of 11 (6356 views)
Thats good news then. Replace all the caps you described if you feel comfortable soldering. Also when you put the new caps in bump the voltage up just a bit. Not sure what uf they are but say the power supply has a 10V 3300uf cap just bump the V to a 16 or 25 but keep the same uf.
www.atlanticav.net
medic22
Apr 23, 2014, 11:03 AM
Post #10 of 11 (6349 views)
Ok. I will do that this weekend. I will let you know the out come when I'm done. Thank you very much!!!
xgc12
Apr 25, 2014, 2:53 PM
Post #11 of 11 (6340 views)
Your welcome. LG and other manufacturers around that era undervalued their caps so its very common. We repair a lot of power supplies that looks the same as yours. Please update us after repair.
www.atlanticav.net
