carrera2
Feb 12, 2011, 6:40 PM
Post #16 of 22
(21553 views)
Re: [kdh2010] NEC PX-42VP4g plasma goes into standby
To All: Sorry this is late, but for anyone else who needs this info - here it is. If your 170v is loading down when the tv is turned on, it is one or more of the current sense resistors making a poor contact. They are .47ohm surface mount resistors. There are three of them located right by q14 & q15, near the largest capacitor on the board. Resolder them (both ends of all three of them), or replace them with a .15 ohm resistor. Hope this helps. Dan Dan, You information is certainly not too late............... Having put the screen away until I had more time, I finally dug it out again today. I re-ran the test and then re-soldered the three resistors you identified. What can I say except: Many thanks, grazie mille, tusen tack, muchas gracias, merci beacoup, danke schön, dank je wel , ta very much!              (that's about the limit of my language abilities) I have now repaired both my screens, and identified that the resistors are the problem on a third power supply I have. Wooo Hoo ! All the very best, you are a star
